  • Jason McDaniel Friend
    #137676
    I’ve been trying to do this for months but can’t get it working. I need it for a client.
    I would like my main body (articles) at the top section as shown in the attached image and above User 5, User 6 and User 7. Please let me know if this is possible. It seems that this would be easy for someone who knows what they are doing.
    1. articles
    bytestor Friend
    #289041
    Well may we know how you get it now? If you can provide us more info if possible a live link we can help you much better.
    Menalto Friend
    #289043
    Can you cut and make a image on how you want it?
    #289055
    I have the image in my post above. Thanks.
    bytestor Friend
    #289149
    Well,
    I just saw ur PM. From wat I see, I believe, the article next to the main menu must be ur main body n you wanted it at the top just above the video?
    If that is what you are looking I suppose the problem you have them down must be coz off the width of the main body article, to make it more clear, as of now you have 2 articles side by side with 2 images in each, it takes a quite a lot of space in width n u need to have ur right I dont use this template personally, but I feel it must be the problem. Back up your site and try give just one article and see how it goes.
    Hope fully it must solve your problem.
    #289162
    No, that is not it at all. The template code makes the articles at the bottom. I wanted a way to change the code so that it is on the top.
This topic contains 6 replies, has 3 voices, and was last updated by  Jason McDaniel 15 years, 11 months ago.
