  • peeka38 Friend
    #137646
    I want to use the layout “with extra modules” same as the front page on a few of my pages. How do I set that up for the rest of my pages?
    I guess the general question is, where do you select the content layout for each page? :confused:
    Thank You
    bytestor Friend
    #288879
    On each and every module edit the settings to appear in every page.
    For Example click any module to edit its settings. You will have the options to select on which pages the modules to appear, select the Radio button ALL so it appears in every page of the site. This radio button must be under the “menu assignments” Click the radio button “All” for “Menus”
    It must work fine,
    Hope it helps you.
    Thanks,
This topic contains 2 replies, has 2 voices, and was last updated by  bytestor 15 years, 10 months ago.
