  • alegioia Friend
    #122593
    Please, i want reduce font-size (see here http://www.italgross.it/menu.gif ), but i don’t know where i must go to modify, can you help me.
    Thank you
    orpheus2510 Friend
    #229531
    It depends from the menu type, you have chosen: if you have a splitmenu, you go to “templatesja_larixja_splitmenu” and open the ja-splitmenu.css, then you search the line in the part “TOP-NAVIGATION” with “font-size: 135%” and change the percent number.
    If you have a transmenu, you go to the “templatesja_larixja_transmenu” and open the ja-transmenuh.css, then you search the line in the part “Added classes by Khanh …” with “font-size: 135%” and change the percent number as well.
    If you are using a cssmenu (son of suckerfish), you go to “templatesja_larixja_cssmenu” and open the ja-sosdmenu.css, then you search the line in the part “STYLING THE MENU” with “font-size: 135%” and change the percent number as well.
    alegioia Friend
    #229534
    Thank you very much, now is ok:D
This topic contains 3 replies, has 2 voices, and was last updated by  alegioia 17 years, 3 months ago.
