mehmetcesit Friend
mehmetcesit
- June 2011
November 23, 2011 at 8:22 pm #171035I have checked many times the instilation guide and user guide but still didnt get this problem done. I want my articles and article links open in a new window either pop up or a new window or a tab window. But just not front page at content view. I have to drag down then see the article 🙁 Not nice. On demo site it opens in a new window and please somebody tell me how you do this? Thanks
By the way I am using Joomla 1.6 and template of JA Teline IV the link to site is: http://www.thekurdish.com
tfosnom Friendtfosnom
- October 2010
- 200 times in 94 posts
November 23, 2011 at 8:33 pm #426188usually when you create the link you are given the option on where it will open by your editor panel
I.E. _self opens in existing window. _blank opens in new window. Basic html stuff that everyone attempting web design should know.
If you use Joomla Content Editor and pay to get the extras the media manager etc. has a drop down menu to help with this kind of selection
Shanemehmetcesit Friendmehmetcesit
- June 2011
November 23, 2011 at 9:45 pm #426195Thanks for replay but I guess you didnt get the question. I am not talking about creating a link in an article. I am talking about more article links on the home page. And I just want to learn how do you guys did on the DEMO JA Teline IV Site. When user clicks an article it opens up in a new window instead of content view.
- June 2011
November 24, 2011 at 6:20 pm #426318JA Forum is disappointing, how many times i have wrote here for a simple problem but seems no one cares even administrator. I started differently about ja now..
Sherlock FriendSherlock
- 2478 times in 2162 posts
November 25, 2011 at 4:57 am #426345hi mehmetcesit,
If i have a correctly understanding about your questions then what you want is when you open a article it should display in a article page only and without any modules around it, right ?
if that you just need to create a menu item which referring directly to that article (or refer to the category the articel belong to) then you do not assign any modules to display with that new menu item.If this is not the case, please give me exact example of what you wish to achieve. You can download the quickstart of Teline and try to crosscheck that the settings are as per the demo.
This topic contains 5 replies, has 3 voices, and was last updated by Sherlock 12 years, 11 months ago.
