reders Friend
reders
- December 2007
- 4 times in 1 posts
June 17, 2008 at 10:10 pm #129799Please help,
I’ve altered the Dravity Template to my spec, but all the png images used on the site display wrong in IE. Is there a global fix to sort this out?You can view my site at:-
http://www.webdesignerblackburn.com
Regards,
Redersbennitos Friendbennitos
- May 2008
- 474 times in 407 posts
June 17, 2008 at 10:12 pm #254254Looks good here in both IE7 and FF, maybe IE6 only?
instantinlaw Friendinstantinlaw
- February 2007
- 210 times in 62 posts
June 17, 2008 at 10:27 pm #254260reders;59879Please help,
Regards,
RedersIE6 does not support transparant png.
There is a plugin over at Joomla.org that is supossed to fix the problem, but I couldn’t get it to work for me.
It’s called ultimate png fix. Give it a try.
You could also hack the index and add the code manually. Do a google for png in IE6 or similar to find the code.
Or, you could make all your png’s backgrounds match the site background, or make them transparant gif’s.
Good luck.Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
June 17, 2008 at 10:53 pm #254266<em>@reders 59879 wrote:</em><blockquote>Please help,
Regards,
Reders</blockquote>I see one error and thats this here:
Designed by Red-Fern Media Solutions - www.red-fern.co.uk
Sherlock FriendSherlock
- 2478 times in 2162 posts
June 30, 2008 at 9:38 am #257167Hi reders
Do you have any successful ?anisjolly Friendanisjolly
- April 2008
- 96 times in 55 posts
July 3, 2008 at 7:14 pm #257860hey reders
you want the Ultimate PNG Fix plugin which you can find for free on the JoomlaWorks website.
The download is on that page – just scroll down to find it.
This plugin is the best one around.
Hope this fixes your issue.
Nice mod for the template – i’m from Bolton by the way.
This topic contains 6 replies, has 6 voices, and was last updated by anisjolly 16 years, 5 months ago.
