March 16, 2014 at 6:40 am #195819cssyeah Moderator
cssyeah
- June 2006
- 121 times in 81 posts
March 18, 2014 at 4:34 am #527091Unfortunately this is not true. Please check again. Here I used the font “chango” (Content heading).
Look at the letter “ę”.http://petycje.liquiddemocracy.pl/
Saguaros ModeratorSaguaros
March 18, 2014 at 7:19 am #527106It seems that this ‘chango’ font family doesn’t support Polish characters well, kindly change to another font.
March 18, 2014 at 1:06 pm #527166Which are, according to you, Polish characters?
I tried “Seymour One”, “Alegreya Sans SC”, “Autour One”, “Hanalei Fill”, “Audiowide”, “Berkshire Swash”, “Ribeye Marrow”, “Rum Raisin”, “Rum Raisin”…
All are “latin extended” and Polish display properly on the Google Font Site …
March 20, 2014 at 7:22 am #527434The problem comes from that ‘latin extended’ charset, I wonder if you did add ‘latin-ext’ subset. So instead of embedding this:
<link href='http://fonts.googleapis.com/css?family=Rum+Raisin' rel='stylesheet' type='text/css'>
you should embed this code:
<link href='http://fonts.googleapis.com/css?family=Rum+Raisin&subset=latin,latin-ext' rel='stylesheet' type='text/css'>
March 20, 2014 at 7:23 pm #527521Saguaros ModeratorSaguaros
March 21, 2014 at 2:00 am #527550You can embed it into head block of your site
– Open the templatesja_elasticablockshead.php file
– Add this line of code:
– Then clear JAT3 cache.1 user says Thank You to Saguaros for this useful post
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 3 voices, and was last updated by Saguaros 10 years, 9 months ago.
