  • ashseo Friend
    #131981
    I am having issue’s with this template, the right hand side bar which has the poll’s, users online and advertisments just below is blocking part of the text in the 2 boxes I have on the homepage, on a large screen, ie: 20 inch, its fine and you can see the whole thing but on my work 15 inch screen it blocks it, is there any way of changing the resolution, or css so that this does not happen?
    it seems fine when i use other templates
    my site address is http://www.ash.uk.net
    many thanks in advance
    Ash
    please if replying could you also email me – me@ash.uk.net
    lcristian Friend
    #264607
    In backend go to Extension -> Template manager and you shoud see “Template Width”
    You have 5 options to play with.
    For a 15” monitor I’d try first the Auto (fluid) option and see where it gets me.
    The best way is to try to make the width of your template to fit into the 1024 x 768 scree resolution or 800 x 600 for 14”
    Good luck.
    ashseo Friend
    #265041
    Thanks thats all sorted now, im having other issue’s with joomla now and not sure if i should post it on this forum or a joomla support forum, one of my pages on tghe site has been indexed by google and its coming out with no pictures or templates
    http://www.ash.uk.net/index.php/index.php/index.php#ja-content
    also, when i try to vote or click on any of the sponsered links on the right hand side, it doesnt redirect all i get is error message, would this be the appropriate place to post this?
    many thanks in advance and if this is not the correct place, please accept my appogies..
    ash
    ash.uk.net
    lcristian Friend
    #265050
    You are using sh404SEF, right?
    Empty your cache or try to set it up the right way.
    Your template has nothing to do with wrong links in google.
    Anyway, to have a better control of how google is seeing your page, get a gmail account and go here :
    http://www.google.com/webmasters/tools/
    Also download a sitemap component for joomla and set it up.
    Good luck!
This topic contains 4 replies, has 2 voices, and was last updated by  lcristian 16 years, 3 months ago.
