September 5, 2016 at 4:54 am #965621
Dear admin, I have finished design my website using JA Medicare template with awesome performance,
After I implement SSL for my website, the website got poor design, absolutely different with the original without SSL.
Please help me to get great design using SSL as good as without SSL.Thanks
September 5, 2016 at 5:10 am #965628Hi
At this time on your site there is only Google font call that is coming from the non SSL URL .
For this go to /templates/ja_medicare/etc/assets.xml
Find<file>http://fonts.googleapis.com/css?family=Roboto+Slab:400,100,300,700</file> <file>http://fonts.googleapis.com/css?family=Roboto:400,300,700</file> <file>http://fonts.googleapis.com/css?family=Roboto+Condensed:400,300,700</file>
replace the http with https , Save and check .
If there is some other issue due to SSL kindly provide description of the issue with screenshot .September 5, 2016 at 5:25 am #965633Pankaj Sharma ModeratorPankaj Sharma
September 5, 2016 at 5:37 am #965636Hi
Kindly share the temp. super user login details via Private reply . So that i can check this issue .September 5, 2016 at 9:07 am #965691This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
September 6, 2016 at 3:23 am #965931Hi
Kindly take full backup of site and update the T3 plugin to latest version .
Let me know if it helps .September 6, 2016 at 3:57 am #965940Pankaj Sharma ModeratorPankaj Sharma
September 6, 2016 at 6:42 am #965966Hi
Latest version is 2.6.1 , please check the download page and you can update using JA Extension manager .September 6, 2016 at 8:21 am #965996September 6, 2016 at 1:39 pm #966071Ok Fix,
I am reupload the backup site.AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 9 replies, has 2 voices, and was last updated by Danar 8 years, 2 months ago.
