November 28, 2016 at 5:23 pm #990535
I have JA Admin template on a domain http://www.elektroprumysl.cz with the template JA Teline V and I have some problems.
1.
JA Admin template does not support pop-up window. These are needed for connecting the article on the topic (template Ja Teline V functionality). How can this be rcorrect-
I have everything associated language. The basic menu is still the default language is English in the JA Admin template. Everything else is OK. Where could by the problem?
Thank you very much
- November 2014
- 3854 times in 3563 posts
November 29, 2016 at 4:44 am #990726Hi,
You can try with my tweak as below:
- Go to file: administrator/templates/ja_admin/index.php
- Find and comment this line of code:
$this->addScript($this->baseurl . '/templates/' . $this->template . '/js/masonry/masonry.pkgd.min.js');
Hope this helps.
November 29, 2016 at 7:11 am #990759Hi,
Perfect, problem number two is solved. Do you still know how to solve problem number one?
Thank you very much.
- November 2014
November 30, 2016 at 1:07 am #991060Hi,
You can give me the Admin login and FTP account via private reply. I will check further
November 30, 2016 at 10:14 am #991219This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
December 2, 2016 at 7:04 am #991719Hi,
ok, but the problem with Topic been resolved. Now the problem is the language setting the main menu administration. It doeas not work.
Thank you very much
- November 2014
December 2, 2016 at 9:58 am #991770Now the problem is the language setting the main menu administration. It doeas not work.
You can clarify this problem in more details: screenshot with description, I will check it for you.
December 5, 2016 at 2:54 pm #992335Hi,
here is my problem.
I have installed Czech language.
Template JA Admin doesn´t show it in the menu, in other parts yes.
When I change to a different template, the language show fine everywhere.
Additionally, the menu – the components are poorly ranks. When I install new components, they aren´t ranked in alphabetical but it is at the end.
Thank you very much
- November 2014
This topic contains 9 replies, has 2 voices, and was last updated by Ninja Lead 8 years ago.
