  • Abdul Kadir Friend
    #144632
    i have problem with popup plugin when i enable Joomla SEO Settings..
    the problem is the plugin not generating correct link for the image to popup…
    example:
    this is the bad link that was generate by the plugin
    http://www.domain.com/section/category/images/stories/image.jpg
    the correct link is:
    http://www.domain.com/images/stories/image.jpg
    please advice for the solution!.
    Sorry for my bad english…
    Thank’s in advance…
    Anonymous Moderator
    #318863
    Hi adinx
    I think it is from your configuration.
    Please make that the url of image is the absolute url.
    Anonymous Moderator
    #318864
    Also, could you please send me your live url, admin account so that i could have a closer look on the issue?
    portalion Friend
    #319780
    I have the same problem.
    When I enable SEO setting system generates wrong path to the picture.
    For example:
    – image location: http://www.domain.com/images/stories/pic.jpg
    – system generates: http://www.domain.com/section/category/images/stories/pic.jpg
    When I set absolute path system generates the same wrong paths.
    Because in the source I can’t see absolute adress I assume it is not accepted by system or editor.
    Please help
    Abdul Kadir Friend
    #319785
    hi, thank’s for your answer,
    i am still migrating my site to teline3 so my installation is in my local computer.. not yet online!.
    i have tried to make subdomain install and test it online but the problem is still exist.
    also tried absolute path but again still no luck…
    i hope there is a solution for this problem.
    Thank’s
    Regard’s
    Adinx
    Abdul Kadir Friend
    #323457
    Hi, i solve the problem by setting the editor plugin to absolute url, and than i use mysql query code below to replace image path of my introtext field in jos_content table of my database.
    update `jos_content` set `introtext` = replace(`introtext`,'images/stories','http://www.domain.com/images/stories')
    i hope some one find this usefull.
    Thank’s
This topic contains 6 replies, has 3 voices, and was last updated by  Abdul Kadir 15 years, 1 month ago.
