  • pepijn2015 Friend
    #208483
    Dear Sir/ Madam,
    I have tried to add two modules on position 1 and 2 with Cagox default 2 template.
    When I open the site on the laptop it works good. But when I open the site on a mobile the modules do not resize below each other. Position 1 and 2 on 1 are on one line (3 and 4 on next line). My pictures are 400 * 400 and then it will not look good. Please look the site url on mobile.
    With regards,
    Pepijn
    Hi Pepijn,
    First of all, you can go to Backend > Extensions > Template manager > select JA Cagox template style > Layout tab > Responsive layout > Extra small
    and Navigate to the position 1 & 2, you can resize each position so that it takes full-width in this extra small layout (mobile layout)
    Refresh your site and see how it goes.
    If image is still not resized, you then can create a new css file call custom.css in this directory: root/templates/ja_cagox/css/
    and add this css rule:
    @media (max-width: 320px) {
    .singlecol.oddcol > img {
    width: 100%;
    Hope this helps.
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 9 years, 6 months ago.
