May 8, 2015 at 10:40 am #206190
Hi everyone,
I’m having trouble locating what variable to modify to make the buttons look right. When I hover, the font goes white like the background, and is unreadable. Any help would be appreciated.
Cheers!
TomC Moderator
TomC
- October 2014
- 3155 times in 2495 posts
May 8, 2015 at 7:44 pm #569976Having a little difficulty trying to identify the correct file path for the CSS rule, but this is the culprit:
.btn-border:hover, .btn-border:focus {
background: none repeat scroll 0 0 #fff;
border-color: #fff;
color: #3498db;
}TomC ModeratorTomC
- October 2014
May 8, 2015 at 7:44 pm #735050Having a little difficulty trying to identify the correct file path for the CSS rule, but this is the culprit:
border-color: #fff;
color: #3498db;
}May 11, 2015 at 9:08 am #570128Thanks Tom,
Where in the CSS files is that bit located? in custom.css? or template.css?
TomC ModeratorTomC
- October 2014
May 11, 2015 at 7:24 pm #570187<em>@malonso 472809 wrote:</em><blockquote>Thanks Tom,
Where in the CSS files is that bit located? in custom.css? or template.css?</blockquote>
Not entirely certain … Your site is encrypting the correct CSS file/path when I try to inspect it online.
Not certain why. :-[TomC ModeratorTomC
- October 2014
May 11, 2015 at 7:24 pm #735259<em>@malonso 472809 wrote:</em><blockquote>Thanks Tom,
Not certain why. :-[May 12, 2015 at 7:16 am #570280Ugh, what could I do to fix it…?
I’ve ran out of ideas…
May 12, 2015 at 7:16 am #735346Ugh, what could I do to fix it…?
- November 2014
- 3854 times in 3563 posts
May 13, 2015 at 10:40 am #570437<em>@malonso 472482 wrote:</em><blockquote>Hi everyone,
Cheers!</blockquote>
I fixed the problem directly on your site with the solution below
Open templates/ja_medicare/local/css/template.css file
find and change
.t3-module a,
.t3-module .mod-articles-category-title {
color: #ffffff
}to
color: #ffffff
You can check it again, let me know if it helps
- November 2014
May 13, 2015 at 10:40 am #735503<em>@malonso 472482 wrote:</em><blockquote>Hi everyone,
find and change
.t3-module a,
color: #ffffff
}to
color: #ffffff
Viewing 11 posts - 1 through 11 (of 11 total)This topic contains 11 replies, has 3 voices, and was last updated by Ninja Lead 9 years, 5 months ago.
