October 4, 2013 at 11:03 am #191152
I used quickstart for j2.4 to display the site like the demo but i can’t get Modules in position 20-23 to display and some Modules not display like the demo. How i can fix this problems. please ?!
Regards,
Fahad Aldaferipavit Moderatorpavit
October 5, 2013 at 7:14 am #508073Thanks Pavit,
Now everything work fine except slideshow dose not show up at all…?!
one more question can i change Flicker & Feed icons in CONNECT section with YouTube & Instagram…?!
October 5, 2013 at 9:49 am #508075Hi
Your slideshow seems to works fine by my side
About the connect module icons you can change icon image with your Youtube and Instagram icon accessing the module “connect”
<p>Donec sed odio dui. Nulla vitae elit libero, a pharetra augue.</p>
<ul class="social-list">
<li class="facebook"><a href="#" title="Facebook"><span class="icon">*</span><strong>Facebook</strong></a></li>
<li class="flickr"><a href="#" title="Flickr"><span class="icon">*</span><strong>Flickr</strong></a></li>
<li class="twitter"><a href="#" title="Twitter"><span class="icon">*</span><strong>Twitter</strong></a></li>
<li class="feed"><a href="#" title="Feed"><span class="icon">*</span><strong>Feed</strong></a></li>
</ul>Changing the social-list.png image in templatesja_briskimages
That is managed by the template.css and style.css file
October 5, 2013 at 10:54 am #508078Ok, Can you gave me an image becouse i don’t see any slideshow when i visit the site…!
I have change the logo image and size but still the size is 80×50…?!
<blockquote>Open templates/ja_brisk/less/variables.less file
</blockquote>
@T3logoWidth: 250px;
@T3logoHeight: 99px;@T3LogoImage: "../images/logo.png";
and I have edit the social-list.png but still don’t see any changes. Why is that…?!
October 5, 2013 at 3:33 pm #508092Hi
Here screenshot of your slideshow.
<blockquote>Open templates/ja_brisk/less/variables.less file</blockquote>
After you changed the variables.less file did you compiled less to css ?
<blockquote>and I have edit the social-list.png but still don’t see any changes. Why is that…?!</blockquote>
You need to edit the png file and change the images with your own
HERE you can find a ja_brisk template userguide
October 5, 2013 at 4:05 pm #508094Can you gave me snapshot on CONNECT section to see if there is some changes or not. please ?!
Last question how can i display all categuray like the demo
October 5, 2013 at 4:31 pm #508096October 5, 2013 at 5:01 pm #508097I used userguide to do some changes but i can’t understand how to make a button in Main Menu to display all Categories like the demo site…?!
October 6, 2013 at 6:23 am #508112To have the All Categories menu item you need to create a new menu item – and choose as type K2 – Categories
October 6, 2013 at 8:14 am #508115When i do that it says “No input file specified.” ?!
October 6, 2013 at 8:42 am #508116This issue is related to the SEO Settings >> Search Engine Friendly URLs enabled i disabled it now and link works
Anyway i can suggest to install the quickstart version of the template in this way you can start to customize an environment already set with all configurations for components and modules as showed on the demo site, so you need only to change your language and set it as RTL
October 6, 2013 at 8:54 am #508117I already install the quickstart version of the template but that what i get 🙂
All Categories button work but it display nothing on my side ?!
October 6, 2013 at 9:13 am #508118<blockquote>I already install the quickstart version of the template but that what i get </blockquote>
Did you installed sample data at the end of procedure ?
October 6, 2013 at 11:30 am #508119When i click on install sample data nothing happens and the logo when i click on compiled less to css nothing happens…?
AuthorPostsViewing 15 posts - 1 through 15 (of 15 total)This topic contains 15 replies, has 2 voices, and was last updated by q8xbox 11 years, 3 months ago.
Position 20-23 does not display and others
