Jeancarlos Rodriguez Friend
- 3 times in 1 posts
January 4, 2013 at 4:23 pm #183647I created a new color theme through theme magic, than i went to use the assignment section and just checked the home menu.. and right after that i havnt been able to put my default position layout to its original place.. please help..
Jeancarlos Rodriguez FriendJeancarlos Rodriguez
January 4, 2013 at 5:27 pm #478461Position 13, 20, 21, 22 and 23 dosen’t show on the front home page…
and position 6 is shown all the way to the right…Jeancarlos Rodriguez FriendJeancarlos Rodriguez
January 4, 2013 at 8:56 pm #478470I tried to reset all layout position and nothing is going back to normal… please help…
Saguaros ModeratorSaguaros
January 5, 2013 at 9:45 am #478513Hi jrod31,
Which version of joomla are you using? and could you post your site url here so that I can check?
January 7, 2013 at 11:01 pm #478830i sent you a private message…
i am using the quick-start package which has joomla 2.5.8 and JA_Brisk 1.0.1, T3 framework 1.0.2Saguaros ModeratorSaguaros
January 9, 2013 at 2:28 am #478995Are you trying to re-intall it, right? since when I access your site, it directs me to installation steps.
January 10, 2013 at 1:05 am #479175Yeah i had to re-installed…. It again…. Needed to finish it up…. Now i am having issue with using the magic theme in the template section… Everytime i try to create a new color theme it freezes…
Please let me know… I think this quick package has issues…Saguaros ModeratorSaguaros
January 10, 2013 at 3:07 am #479194Hi,
I tried to change color, size via ThemeMagic and it still worked. Pls describe step by step to reproduce that error
<blockquote>
</blockquote>January 11, 2013 at 7:23 pm #479408Go to your template setting. then go to Layout tab – Then click on layout and then home layout. Save and check. I did this and it worked. But now my articles won’t show in the other pages.
January 11, 2013 at 7:49 pm #479411Any fix for the articles to show up?
January 12, 2013 at 2:35 am #479439As the reply of my colleague in this thread: http://www.joomlart.com/forums/topic/brisk-j-2-5-or-j-3-0-shows-only-modules-no-main-content-help/#post-473103
The home layout doesn’t include mainbody block so that it doesn’t show content. An it is currently assigned to Home style only: http://easycaptures.com/fs/uploaded/511/7912971695.png
If you want to use this home layout in other page, you can add mainbody block like in above thread, or you can assign other style in template manager to other pages.
January 14, 2013 at 5:33 pm #479672<em>@shaks 354714 wrote:</em><blockquote>Any fix for the articles to show up?</blockquote>
No.. I had to re-install the complete site…. this template has several issues.. i never had any issues with any template from here… but this one does…
January 17, 2013 at 1:46 pm #480199I have to fully agree here, the template setup and changes are VERY confusing, either a good video or a redesign of the way it works is needed badly, i am quite seasoned in creating templates and adjusting them in joomla, but this is really ‘ThemeMagic’ but in a very bad way. Hope the developers read this and will take these comments on this template seriously, because if this continues with all the new templates we will stop our developer license.
This topic contains 13 replies, has 4 voices, and was last updated by 040hosting 11 years, 11 months ago.
