  • easyweb Friend
    #154534
    Hi to all,
    since a few days, information on position Left and on position Right goes on the bottom of my page.
    Only on the home page.
    I don’t change anything.
    I try to remove all the modules on position Left and on the Right Position and activate some module again, but that’s doesn’t work.
    For example : i put
    – module Main menu on the left position
    – module Nouvelles aires on the right position.
    See on http://www.airemotorhome.be
    But both are on the bottom.
    Thanks for helping.
    Richard
    aman204 Friend
    #356371
    Please check in for xhtml validation errors mainly relative to mismatch of div tags in articles and correct them
    http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.airemotorhome.be%2F
    easyweb Friend
    #356612
    Thanks for all.
    You’re right. I had mismatch tag in a new article i wrote.
    Thanks for the link of validator; i will check all my others sites.
    Richard
    aman204 Friend
    #356617
    Please change prefix to solved if you are done with it as it would help other members also looking for the same solution 🙂
This topic contains 4 replies, has 2 voices, and was last updated by  aman204 14 years, 3 months ago.
