  • anthonyberot Friend
    #174538
    I using the the JA Nex template and position left is not showing up in the list of available positions that I can use for a module.
    when i type http://contrastnewspaper.burroket.com/index.php?tp=1 it is there. how can i activate it. firebug did not help.
    TomC Moderator
    #441462
    <em>@anthonyberot 304554 wrote:</em><blockquote>I using the the JA Nex template and position left is not showing up in the list of available positions that I can use for a module.
    when i type http://contrastnewspaper.burroket.com/index.php?tp=1 it is there. how can i activate it. firebug did not help.</blockquote>
    Try manually typing in “left” in the position field for the module you want to position there.
    anthonyberot Friend
    #441650
    Thank you, I will try that and let you know.
    I will like to add that the support here is TOPS, A1, 10/10 by ever description this is the best support.
This topic contains 3 replies, has 2 voices, and was last updated by  anthonyberot 12 years, 9 months ago.
