  • uzvezda Friend
    #187035
    is it possible to set to show category articles or k2 items or categories on main body position. Or is needed to be done manualy.
    I would like to set in Joomla 3.0.
    If anyone any idea I would appreciate it.
    thanks.
    z.
    Ninja Lead Moderator
    #491019
    To show k2 in main body, go to the menu then click “New” and then for the menu item type select K2 >> item(Item, Item edit form, Categories, Tag User page (blog), Latest items from (one or more) users or categories).
    K2 has a lot of extra features such as tags, article images, videos, image galleries, attachments, and comments.
    By the way, you can import your Joomla article to K2 but you can’t do the opposite, so that’s something to consider long term.
    For more information, check out K2’s documentation: getk2.org/documentation
    uzvezda Friend
    #491097
    I have set up over menu and it shows.
    I order it with label Featured and got Featured label on corrner eventhough I set to hide it in category view.
    Where else is possible to set it?
    thank you
    z
    #491305
    You can send me the screenshot and URL of your site, try to help you out then.
This topic contains 4 replies, has 2 voices, and was last updated by  Ninja Lead 11 years, 8 months ago.
