June 22, 2011 at 2:35 pm #165541
Hello
I am trying to setup position mega but i confused. I read some theads but nothing happend.
I want in the mega menu to place k2_login, a subcribe module, k2_comment and to show with pics like your demo template.
Please help me. My site is http://www.sportorama.gr/sport_v2
Mixalis
June 23, 2011 at 4:04 pm #398079Hello does anyone can help me ???
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
June 23, 2011 at 4:42 pm #398084<em>@mpiper 248944 wrote:</em><blockquote>
I want in the mega menu to place k2_login, a subcribe module, k2_comment and to show with pics like your demo template.Please help me. My site is http://www.sportorama.gr/sport_v2
Mixalis</blockquote>
Hi Mixalis . .I am not 100% clear on what it is you are trying to accomplish …. are you trying to add K2 modules within one of your mega menu dropdown boxes? As I do not read or understand the language your site is in – which menu item are you trying to work with?
P.S. – May I ask when your JA membership expired? Do you have any plans to re-join us? 🙂
June 24, 2011 at 6:10 am #398155I want to show modules (k2_login, subcribe module etc) with icons in mega position (not in mega menu)
I have renew my membership
JATC Standard Membership – 1 year 263179 21 Jun 2011 21 Jun 2012
Why r u asking ?
himangi Friendhimangi
- April 2011
- 345 times in 332 posts
June 27, 2011 at 10:29 am #398634Hi mpiper,
Please use the username and password with which you have purchased the JATC membership, so that it will be easier for us to support you, and you can take the advantage of being a paid member..
For your current problem, I have created a menu container called topmega, which should contain the menu items you want to display in mega position. Now you can see the Login menu item on the extreme right on the navigation area.
Currently the menu item has class ‘nav-member’, it wont show any image, since the styling is not defined for it as it is in the demo template.
To define the styling for nav-member, open your template.css file and find styling for say ‘nav-blog’, copy – paste it in the same file, and replace nav-blog with nav-member.
Then upload the icon for login link in templates/your_template/images folder, this is where the icon-blog.png etc files are placed.
June 29, 2011 at 6:02 am #399006Thanks a lot. How can i publish k2_comment in second column ? I set in menu Login column =2 but i get an error when the webpage loads.
Know i have a problem with top-bar. The titles are in a mess. see the attach photo.
- April 2011
June 29, 2011 at 7:57 am #399038About the top bar ?
- April 2011
June 29, 2011 at 8:55 am #399052Everything ok. Thanks a lot
powerfuldarkangel Friendpowerfuldarkangel
- June 2011
August 2, 2011 at 9:08 pm #404237I have almost the same issue… I have this custom html module that I want to place next to the login at the mega position…. In the demo next to the login you have a module showing the lastest comments right? Well I want to place a different module there… I tried assigning the module to the mega position but it doesnt show… What am I doing wrong? :((
- April 2011
August 3, 2011 at 5:03 am #404270Hi
Can you please provide your site url and superadmin details at http://support.joomlart.com/index.php?/Tickets/Ticket/View/78078 Also tell me which custom module you want to show there so that I can check how you have setup the module in mega position and why that isnt working.
August 17, 2011 at 4:42 pm #406742My mega position not appear well. See http://www.sportorama.gr on the top right. I have update t3 framework and then the problem appears.
What happend. Please help !!!!
August 19, 2011 at 7:44 am #407026Please help my menu (mega position) on the top right of my site not working good. i did’t change anything i have only update t3 framework.
chavan Friendchavan
- October 2014
- 1440 times in 1290 posts
August 19, 2011 at 9:42 am #407047Hi mpiper
Could you provide me ftp account of your site via http://support.joomlart.com/index.php?/Tickets/Ticket/View/75242? I will help you solve your problem.
AuthorPostsThis topic contains 20 replies, has 5 voices, and was last updated by mpiper 13 years, 4 months ago.
