  • bibo07 Friend
    #138788
    Hy at all…!
    I have a problem with Joomla 1.015 and Virtuemart 1.015 with JA Zeolite template:
    1: I cannot made a position named ja-slideshow because it was impossible to write “ja-slideshow” (iI ceck the database of Joomla 1.015 the max char allowed is only 10 not 12 like ja-slideshow) what canI do? It is no possible to solve this situation?
    2: How is the correct configuration of Special Product like mod_virtuemart_featureprod, How can I make a product in the list? With category or id?
    I think that the problem is because the configuration guide is not all for J 1.015 but they take a part of joomla 1.5 and the difference is big.
    3: Also the icon image menù don’t go… I don’t have a parameter like J 1.5 how can I configure the image in a menù?
    4: another big problem, in the guide there is a theme configuration for Virtuemart component but this is impossible for virtuemart 1.015. Now I have a template file to do this, but in another template like Xenia II Shopping. To arrange this I have to reprogramming the template fiel for browsing and for list and product?
    PLEASE CAN YOU ARRANGE THE GUIDE FOR JOOMLA 1.15 and Viertuemart 1.015 now there is a mix!!!
    Anonymous Moderator
    #294538
    Hi bibo07,
    I would like to anwser your question as follows:
    => You can create a short text position (For example: slide) and select the ja slideshow module for this issue.
    => You only select a product to special product.
    => Current this template does not support your idea.
    =>As you are requesting heavy customization, I am afraid that you have to handle the changes at your end.
    Alternatively, please take into consideration to post your requirements on Joomlancers.com to find a talent freelancer for your project.
    I am sorry for not being of much help in this case.
    bibo07 Friend
    #294596
    Tank’s for your reply:
    1: I create a short tex position but the module not show…
    2: Ok for help I understard the function!
    3: Ok the icon menu is only for J 1.15
    4: I try to contact
    I have 2 more question’s:
    1: how can I do to solve a lot of error in validation CSS??
    look at this link:
    http://jigsaw.w3.org/css-validator/validator?uri=http%3A%2F%2Fwww.supply.it&profile=css21&usermedium=all&warning=1&lang=it
    my web site now is online is http://www.supply.it
    2: Hoe can I do to eliminate the pagenav in the home page?
    <<Inizio <Prec.Pross. >Fine>> ???
    Many thank’s for the help!!
    Roberto
    bibo07 Friend
    #294757
    anybody can answer??
    Anonymous Moderator
    #295120
    Hi bibo07,
    I would like to answer your questions as follows:
    look at this link:
    http://jigsaw.w3.org/css-validator/v…ning=1&lang=it
    => I could not view your link, maybe this issue is from my internet.
    => You can change to your requirement in templatesja_zeolitehtmlpagination.php file.
    bibo07 Friend
    #295129
    Ok…
    you cannot view the link, but can you try to validate css? You can see how many errors you can find.!!
    I use Joomla 1.015 and there no exist templatesja_zeolitehtmlpagination.php file (I think that this is for Joomla 1.15) how can I do to change the pagination??
    many thank’s
    roberto
    Anonymous Moderator
    #298128
    Hi bibo07,
    I think i have fixed this issue to help you.
    Could i close this thread?
This topic contains 7 replies, has 2 voices, and was last updated by Anonymous 15 years, 9 months ago.
