  • lemka Friend
    #135244
    Hello there,
    I am newbie in Joomla, and I have I little question.
    is there possibilities how I can change a position of ARTICLE with company logo above mod_virtuemart_featureprod and mod_ja_vmproductslide.
    default state is under mod_virtuemart_featureprod and mod_ja_vmproductslide.
    thx for help
    my system Joomla 1.5.7 + VM 1.1.2
    http://www.proinexinstruments.com
    nefar Friend
    #278751
    I think I know what you’re reffering to and it’s something I want to do as well. I think, though I am not sure that you have to go into module manager, pick the modules and actually change the “Order”. This is what I was going to try. The only other thing I can think of is to actually change the template code on what mod loads in what table.
    lemka Friend
    #278848
    thanks for reply, change the order doesn’t work, because i have only one article on front-page. and the slideshow a featured modules can’t change position. But i found a solution
    in file templatesja_mesoliteindex.html
    I change the order of line, where modules is loaded and position of article was upper, that i need. (i hope, that’s didn’t something problem with code)
    and my next problem is :
    is the possibilities how i can change <Heading> tag for my CART module.
    default is h2 and i need, h3 e.g..
    and is there option, where i can set a <Heading> tag for main menu in virtuemart ?
    thanks for help Roman
    site :http://www.proinexinstruments.com
This topic contains 3 replies, has 2 voices, and was last updated by  lemka 16 years, 2 months ago.
