  • ekaplan1020 Friend
    #170200
    I like how Joomlart has their modules positioned on the bottom half of their front page.
    I am using JA community plus and would like to have the same layout for my site. I don’t know which modules they are, but they are the testimonial, From our blog, tweets and connect with us, and the RSS feeds. I have a newsletter module I would put in place of the one here. Could someone please tell me what I need to modify to do that and which modules I will need.
    jooservices Friend
    #422716
    At first please check with JA Community Plus template position. And you can see which position you should to use.
    In our homepage we have our unique template design :). But you can custom your template in template profile to add new module position and update css to style it.
    Thank you
    Viet Vu
    ekaplan1020 Friend
    #423010
    I understand it is Joomlart’s own custom template. I just can’t figure out how to make a 3 column module positions under the content section so it spans the width. I tried to mess with the layout, but it didn’t work correctly. What type should I put and where do I put the block?
    Also, I wasn’t sure if the modules you used were Joomlart modules and if they were available.
    jooservices Friend
    #423034
    You can insert code in Template Manager (Backend)
    <blocks name="middle" colwidth="22">
    <block name="content-bottom" type="spotlight">col1,col2,col3</block>
    </blocks>
    or you open here that position module
    http://wiki.joomlart.com/wiki/JA_Template_Framework/Guides
This topic contains 4 replies, has 2 voices, and was last updated by  jooservices 13 years ago.
