  • dottorbonfy Friend
    #169049
    Hallo everyone!
    I have a question.
    If i have, a JA RAVE 1.5 system preinstalled into a site and i want to install a JA METHYS 1.5 how i do? I have installed the template but i dont see some position…. why?
    jneubauer Friend
    #415477
    Once you install, and activate the new template, that should be it!
    Your template should show on the front end immediately.
    dottorbonfy Friend
    #415479
    Yes, the template function but if i create a new module this not have a position that i see in another site realized with a STARTUP of JA METHYIS, understand my problem?
    dottorbonfy Friend
    #415483
    16121 Without certain position
    16122 Correct from another site.
    1. Without
    2. Correct
    dottorbonfy Friend
    #415508
    Anyone have suggest?
    Now i have:
    1) re-copy the website files into the root;
    2) dump the database and connect to the site
    3) test the site, the site is ok, frontend and backend
    4) Install a template zip, operation ok
    5) select the JA-METYS template like as Default, this is ok
    6) run into the Module section and verify if certain position is activated but not appear….
This topic contains 5 replies, has 2 voices, and was last updated by  dottorbonfy 13 years, 3 months ago.
