August 6, 2008 at 7:29 pm #131871
Hi all,
I have a little problem, please see:
The right modules change place?
Any suggestions?
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
August 6, 2008 at 8:24 pm #264174Give a list over changes you have done to the template and your set up?
August 6, 2008 at 8:25 pm #264176August 6, 2008 at 8:27 pm #264177I have not done any changes to the template, I just updated the new JATeline II template v1.5 to Joomla 1.5 last night.
- May 2007
August 6, 2008 at 8:29 pm #264178Give a list over changes you have done to the template and your set up?
And a copy of your index.php fileAugust 6, 2008 at 8:45 pm #264180Here is a copy of the template index.php file below:
<?php
* @copyright Copyright (C) 2005 – 2007 Open Source Matters. All rights reserved.
* @license GNU/GPL, see LICENSE.php
* Joomla! is free software. This version may have been modified pursuant
* to the GNU General Public License, and as distributed it includes or
* is derivative of works licensed under the GNU General Public License or
* other free or open source software licenses.
* See COPYRIGHT.php for copyright notices and details.
*/// no direct access
defined( ‘_JEXEC’ ) or die( ‘Restricted access’ );include_once (dirname(__FILE__).DS.’ja_vars_1.5.php’);
<!DOCTYPE html PUBLIC “-//W3C//DTD XHTML 1.0 Transitional//EN” “http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd”>
<html xmlns=”http://www.w3.org/1999/xhtml” xml:lang=”<?php echo $this->language; ?>” lang=”<?php echo $this->language; ?>”>
<head>
<jdoc:include type=”head” />
<?php JHTML::_(‘behavior.mootools’); ?><link rel=”stylesheet” href=”<?php echo $tmpTools->baseurl(); ?>templates/system/css/system.css” type=”text/css” />
<link rel=”stylesheet” href=”<?php echo $tmpTools->baseurl(); ?>templates/system/css/general.css” type=”text/css” />
<link rel=”stylesheet” href=”<?php echo $tmpTools->templateurl(); ?>/css/editor.css” type=”text/css” /><link rel=”stylesheet” href=”<?php echo $tmpTools->templateurl(); ?>/highslide/highslide.css” type=”text/css” />
<link rel=”stylesheet” href=”<?php echo $tmpTools->templateurl(); ?>/css/template.css” type=”text/css” />
<link rel=”stylesheet” href=”<?php echo $tmpTools->templateurl(); ?>/css/typo.css” type=”text/css” />
<link rel=”stylesheet” href=”<?php echo $tmpTools->templateurl(); ?>/css/ja.news.css” type=”text/css” />
<link href=”<?php echo $tmpTools->templateurl(); ?>/mootabs/mootabs1.2.css” rel=”stylesheet” type=”text/css” />
<script language=”javascript” type=”text/javascript” src=”<?php echo $tmpTools->templateurl(); ?>/js/ja.script.js”></script><script language=”javascript” type=”text/javascript” src=”<?php echo $tmpTools->templateurl(); ?>/highslide/swfobject.js”></script>
<script language=”javascript” type=”text/javascript” src=”<?php echo $tmpTools->templateurl(); ?>/highslide/highslide-with-html.packed.js”></script><!– Menu head –>
<?php $jamenu->genMenuHead(); ?><link href=”<?php echo $tmpTools->templateurl(); ?>/css/colors/theme<?php echo $tmpTools->getThemeForSection(); ?>.css” rel=”stylesheet” type=”text/css” />
<style type=”text/css”>
.clearfix {height: 1%;}
img {border: none;}
</style>
.clearfix {display: inline-block;}
</style>
<!–><?php if ($tmpTools->isIE6()) { ?>
var siteurl = ‘<?php echo $tmpTools->baseurl();?>’;
</script>
<?php } ?><script type=”text/javascript”>
hs.graphicsDir = ‘<?php echo $tmpTools->templateurl(); ?>/highslide/graphics/’;
hs.showCredits = true; // you can set this to false if you want
hs.creditsText = ‘Powered by SouthAsianLife.com’;
hs.creditsHref = ‘http://southasianlife.com/’;
hs.creditsTitle =’Go to homepage’;
</script></head>
<body id=”bd” class=”<?php echo $tmpTools->getParam(JA_TOOL_SCREEN);?> fs<?php echo $tmpTools->getParam(JA_TOOL_FONT);?>” >
<a name=”Top” id=”Top”></a>
<ul class=”accessibility”>
<li><a href=”<?php echo $tmpTools->getCurrentURL();?>#ja-content” title=”<?php echo JText::_(“Skip to content”);?>”><?php echo JText::_(“Skip to content”);?></a></li>
<li><a href=”<?php echo $tmpTools->getCurrentURL();?>#ja-mainnav” title=”<?php echo JText::_(“Skip to main navigation”);?>”><?php echo JText::_(“Skip to main navigation”);?></a></li>
<li><a href=”<?php echo $tmpTools->getCurrentURL();?>#ja-col1″ title=”<?php echo JText::_(“Skip to 1st column”);?>”><?php echo JText::_(“Skip to 1st column”);?></a></li>
<li><a href=”<?php echo $tmpTools->getCurrentURL();?>#ja-col2″ title=”<?php echo JText::_(“Skip to 2nd column”);?>”><?php echo JText::_(“Skip to 2nd column”);?></a></li>
</ul><div id=”ja-wrapper”>
<!– BEGIN: HEADER –>
<div id=”topbanner”>
<?php mosLoadModules(‘topbanner’, -1); ?></div><div id=”ja-headerwrap”>
<div id=”ja-header” class=”clearfix”><?php
$siteName = $tmpTools->sitename();
if ($tmpTools->getParam(‘logoType’)==’image’) { ?>
<h1 class=”logo”>
<a href=”index.php” title=”<?php echo $siteName; ?>”><span><?php echo $siteName; ?></span></a>
</h1>
<?php } else {
$logoText = (trim($tmpTools->getParam(‘logoText’))==”) ? $config->sitename : $tmpTools->getParam(‘logoText’);
$sloganText = (trim($tmpTools->getParam(‘sloganText’))==”) ? JText::_(‘SITE SLOGAN’) : $tmpTools->getParam(‘sloganText’); ?>
<h1 class=”logo-text”>
<a href=”index.php” title=”<?php echo $siteName; ?>”><span><?php echo $logoText; ?></span></a>
</h1>
<p class=”site-slogan”><?php echo $sloganText;?></p>
<?php } ?><div id=”ja-headtools” class=”ja-headtool”>
<div class=”ja-innerpad clearfix”><div class=”ja-day”>
<?php
echo “<span>”.date (‘l’).”</span>”;
echo ” <div>”.date (‘M’).” “.date (‘d’).date (‘S’).”</div>”;
</div><ul>
<jdoc:include type=”modules” name=”ja-login” />
<!–module search–>
<?php if($this->countModules(‘user4’)) : ?>
<jdoc:include type=”modules” name=”user4″ />
<?php endif; ?>
</ul><?php if ($tmpTools->getParam(JA_TOOL_USER)) { ?>
<div id=”ja-usertools”>
<strong>Text size</strong><?php $tmpTools->genToolMenu($tmpTools->getParam(JA_TOOL_USER)); ?>
</div>
<?php } ?></div>
</div></div>
</div>
<!– END: HEADER –><!– BEGIN: MAIN NAVIGATION –>
<div id=”ja-mainnavwrap”>
<div id=”ja-mainnav” class=”clearfix”>
<?php $jamenu->genMenu (0); ?>
</div>
</div>
<?php if ($hasSubnav) { ?>
<div id=”ja-subnavwrap”>
<div id=”ja-subnav” class=”clearfix”>
<?php $jamenu->genMenu (1,1); ?>
</div>
</div>
<?php } ?>
<!– END: MAIN NAVIGATION –><div id=”ja-containerwrap<?php echo $divid; ?>” class=”clearfix”>
<div id=”ja-container”>
<div id=”ja-container-inner” class=”clearfix”><!– BEGIN: CONTENT –>
<div id=”ja-content”>
<div class=”ja-innerpad clearfix”><jdoc:include type=”message” />
<?php if(!$tmpTools->isFrontPage()) : ?>
<div id=”ja-pathway”>
<jdoc:include type=”module” name=”breadcrumbs” />
</div>
<?php endif ; ?><div id=”ja-current-content”>
<jdoc:include type=”component” />
<?php endif; ?><!– BEGIN: JAZIN –>
<?php if($tmpTools->isFrontPage()) : ?>
<div id=”jazin-fp”>
<jdoc:include type=”modules” name=”ja-news” style=”raw” />
</div>
<?php endif; ?>
<!– END: JAZIN –></div>
<?php
$spotlight = array (‘user8′,’user9’);
$botsl = $tmpTools->calSpotlight ($spotlight,$tmpTools->isOP()?100:99.9);
if( $botsl ) {
<!– BEGIN: BOTTOM SPOTLIGHT –>
<div id=”ja-botsl” class=”clearfix”><?php if( $this->countModules(‘user8’) ) {?>
<div class=”ja-box<?php echo $botsl[‘user8’][‘class’]; ?>” style=”width: <?php echo $botsl[‘user8’][‘width’]; ?>;”>
<jdoc:include type=”modules” name=”user8″ style=”xhtml” />
</div>
<?php } ?><?php if( $this->countModules(‘user9’) ) {?>
<div class=”ja-box<?php echo $botsl[‘user9’][‘class’]; ?>” style=”width: <?php echo $botsl[‘user9’][‘width’]; ?>;”>
<jdoc:include type=”modules” name=”user9″ style=”xhtml” />
</div>
<?php } ?></div>
<!– END: BOTTOM SPOTLIGHT –>
<?php } ?><?php if($this->countModules(‘banner’)) : ?>
<!– BEGIN: BANNER –>
<div id=”ja-banner”>
<jdoc:include type=”modules” name=”banner” />
</div>
<!– END: BANNER –>
<?php endif; ?></div>
</div>
<!– END: CONTENT –><?php if ($ja_left || $ja_right || $ja_masscol) { ?>
<!– BEGIN: COLUMNS –>
<div id=”ja-colwrap”><?php if ($ja_masscol) { ?>
<!– BEGIN: MASSCOL –>
<div id=”ja-colmass” class=”clearfix”>
<div class=”ja-innerpad”><jdoc:include type=”modules” name=”user5″ style=”xhtml” />
<?php if ($this->countModules(‘user6’)) : ?>
<script language=”javascript” type=”text/javascript” src=”<?php echo $tmpTools->templateurl(); ?>/mootabs/mootabs1.2.js”></script>
window.addEvent(‘load’, initmootabs);
function initmootabs() {
myTabs1 = new jamootabs(‘ja-tabs’, {
<?php echo $ja_mootabs_options; ?>
</script>
<div id=”ja-tabswrap”>
<div id=”ja-tabs” class=”clearfix”>
<div class=”ja-tab-panels”>
<jdoc:include type=”modules” name=”user6″ style=”xhtml” />
</div>
</div>
</div>
<?php endif; ?><jdoc:include type=”modules” name=”user7″ style=”xhtml” />
</div>
</div>
<!– END: MASSCOL –>
<?php } ?><div id=”ja-cols” class=”clearfix”>
<?php if ($ja_left) { ?>
<div id=”ja-col1″>
<jdoc:include type=”modules” name=”left” style=”xhtml” />
</div>
</div>
<?php } ?><?php if ($ja_right) { ?>
<div id=”ja-col2″>
<jdoc:include type=”modules” name=”right” style=”xhtml” />
</div>
</div>
<?php } ?>
</div></div><br />
<!– END: COLUMNS –>
<?php } ?></div></div></div>
<!– BEGIN: FOOTER –>
<div id=”ja-footerwrap” class=”clearfix”>
<div id=”ja-footer”>
<jdoc:include type=”modules” name=”user3″ />
<jdoc:include type=”modules” name=”footer” />
<div class=”ja-cert”>
<jdoc:include type=”modules” name=”syndicate” />
</div>
</div>
</div>
<!– END: FOOTER –></div>
<jdoc:include type=”modules” name=”debug” />
</body>
</html>
August 6, 2008 at 11:18 pm #264207Any thoughts?
This topic contains 8 replies, has 4 voices, and was last updated by nabetfa 16 years, 5 months ago.
