  • matgray87 Friend
    #183164
    I’m really struggling to get my head round these positions in JA Teline IV… I’ve followed the positions tutorials, but still to no avail.
    From the original layout:
    <?xml version="1.0" encoding="utf-8"?>
    <layout name="desktop">
    <!--Extra css load for this layout-->
    <stylesheets>
    </stylesheets>
    <block name="absolute" type="modules" style="raw">absolute</block>
    <block name="header" type="header"></block>
    <block name="topmegamenu" type="topmega"></block>
    <block name="mainnav" type="mainnav"></block>
    <block name="topbar" type="topbar"></block>
    <block name="cpanel" type="usertools/cpanel"></block>
    <block name="slideshow" type="modules" style="raw">slideshow</block>
    <block name="topsl1" type="spotlight" special="left" specialwidth="66">sl1-l,sl1-r</block>
    <block name="topsl2" type="spotlight">user1,user2,user3,user4,user5</block>
    </blocks>
    <blocks name="middle" main-inner="1" colwidth="17">
    <block name="content-top" style="raw">content-top</block>
    <block name="content-bottom" style="raw">content-bot</block>
    <block name="content-mass-top" style="raw" type="tabs">ja-news-1,ja-news-2,ja-news-3</block>
    <block name="content-mass-bottom">content-mass-bot</block>
    <block name="right-mass-top">col-mass-top</block>
    <block name="right-mass-bottom">col-mass-bot</block>
    <block name="inset1">left</block>
    <block name="right1">right1</block>
    <block name="right2">right2</block>
    </blocks>
    <block name="botsl1" type="spotlight">user6,user7,user8,user9,user10</block>
    <block name="botsl2" type="spotlight" special="left" specialwidth="66">user11,user12</block>
    <block name="footer" type="footer" main-inner="1"></block>
    </blocks>
    </layout>
    I’m trying to add a position above ja-news-1 / 2 / 3 positions, but not within the tabs, so that the Featured News section is part of the ‘middle’ block instead of the ‘top’ block.
    Hopefully that will also mean that the right column (col-mass-top, right-1, right-2, col-mass-bottom) spans the whole content (including the featured news).
    Link to site HERE
    Many thanks in advance for your help…
    matgray87 Friend
    #476541
    I know this should be really simple, but I’ve been playing around today, and still can’t get it… can anyone please help!?
    Thanks,
    Matt
    HeR0 Friend
    #476624
    Hi Matgray87,
    You should try to use user1, user2, … position
    matgray87 Friend
    #476774
    Hi HeR0,
    Unfortunately, user1 is still in the top section, not in the mid section, so it’s still not suitable…
    I need it to appear as the attached image…any other suggestions?
    Thanks,
    Matt
    1. positions
    HeR0 Friend
    #476855
    Hi Matgray87,
    Try swap content-mass-top with content-top as below:
    <block name="content-mass-top" style="raw">content-top</block>
    <block name="content-top" style="raw" type="tabs">ja-news-1,ja-news-2,ja-news-3</block>
    </blocks>
    However, you need make some change in css for it.
This topic contains 5 replies, has 2 voices, and was last updated by  HeR0 12 years ago.
