  • bnappy1 Friend
    #126461
    I would like to use the Newsflash in the “Top” Module position but would like my header images to change also. Is there a way to do that? I’m using 1.5. I kind of want the effect from Rochea. Any suggestions?
    Brandon
    Menalto Friend
    #241852
    Ummmm, thats possible to get done yes. But it require some work
    bnappy1 Friend
    #241856
    A lot of work? Can you point me in the right direction on how to get it done?
    #241911
    Hi bnappy1.
    You should download Rochea quickstart 1.5 and install it to study. I think you will understand how to do.
This topic contains 4 replies, has 3 voices, and was last updated by  Sherlock 16 years, 9 months ago.
