  • kpanchoo Friend
    #163255
    the previous and next arrows are the wrong way round — how do i fix this?
    http://www.sarolta.tv/web/
    Phill Moderator
    #388422
    They are simply images and are how the designer made them. If you wish to have them a different way you would have the edit the images (templates/ja_community_plus/images/pagenav-bg.gif), create a second image for the next box and then edit some css to point to the new next box button. Currently both buttons can use the same image hence the css can call the image for both sides. If you edited it you would need a different image for both sides.
This topic contains 2 replies, has 2 voices, and was last updated by  Phill 13 years, 8 months ago.
