  • ceydakoc Friend
    #178927
    jatravels front page i want to show iframe . the iframe code i got is <header> and <body> sections where can i put theme in joomla? after i put these codes i want to call iframe whit these code<script>addEpowerIFrame(“xztravel”)</script>
    thank you
    #460452
    HI Ceydakoc,
    I think you can copy the folder of pluginssystemjat3jat3base-themesdefaultpage paste it to the template folder templates/your_template/ then you open the file templates/your_template/page/default.php there you can insert your iframe code.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 12 years, 6 months ago.
