  • irentxun Friend
    #196790
    I installed the template with sample data and do not appear in the shop menu appears only 404 page.
    in submenu of shop menu
    You can help me?
    Thank you very much.
    Juan Carlos
    Your website is not reachable you are sure it is the correct url for it ?
    irentxun Friend
    #531040
    yeah is correct url!!!
    http://www.fotonizate.com
    please, help me!!!
    pb66 Friend
    #531051
    This template supports Easyblog and Joomshopping (ie there is css to make them display nice).
    The actual components won’t be installed with the quickstart. You need to download them separately and install.
    Hope this helps!
    Regards,
    Hi @irentxun
    Please send me via Private Message a super user account to your website i will check your configuration
This topic contains 5 replies, has 3 voices, and was last updated by  pavit 10 years, 8 months ago.
