test melih
 melih
  • Ivan Friend
    #911418
    Help me please !
    What I just did.
    This does not appear in my CSS styles for social buttons .
    Styles is not in social link and JA Bookmark!!!
    1. Screen-Shot-2016-04-08-at-22.25.19
    2. Screen-Shot-2016-04-08-at-22.25.47
    Ivan Friend
    #911500
    Please could you help me!
    I have two months can not fix CSS.
    As I understand CSS AddThis taken from the server , but as it is on the override that in my template?
    If you want , I will give access to ftp
    Pankaj Sharma Moderator
    #912034
    Kindly Post your site super user details Via Private reply option Here . So that i can check this problem on your site .
    Ivan Friend
    #912465
    Ivan Friend
    #912466
    If you want I can send Internet access is an FTP
    #912610
    I fixed this issue directly on your site , You can see my changes in custom.css file .
    Kindly check site now .
    Ivan Friend
    #917249
    OK I can see it working for the social link
    But it is not working for the JA Bookmark , all the CSS also does not appear
    Ivan Friend
    #917253
    And more problem with white background
    Please fix!
    1. Screen-Shot-2016-04-13-at-00.26.49
    #917303
    I fixed it . Please check it now .
    Ivan Friend
    #917373
    Tell me please ! But how to fix JA Bookmark?
    I inserted the code created custom.css file, but I did not become a normal CSS
    UPD: Explain, please ,
    If I make changes to custom.css, that these changes be made to work in the template ( use ) ?
    1. Screen-Shot-2016-04-13-at-09.51.26
    #917408
    it looks fine , Kindly clean your browser cache and check .
This topic contains 10 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 9 months ago.
