  • eightyfive Friend
    #994650
    Good evening,
    I was trying the demo last week and wanted to use the alpha version, but when following the tutorial, I couldn’t even get to the Live Edit.
    Although the Edit This Page appears, when hitting it the following message appears:
    malformed
    The url at that point is …/index.php?jub=edit
    Is anyone getting the same problem?
    How can it be solved?
    Arvind Chauhan Moderator
    #994735
    Hi @eightyfive,
    Thanks for your report, today we will release Alpha2 version, a bug fix version, at that time, the issue could be fixed.
    Regards.
This topic contains 1 reply, has 2 voices, and was last updated by  Arvind Chauhan 7 years, 11 months ago.
