  • wchua Friend
    #149368
    Hi, I’m trying to insert “SEO” in one of the top tabs of the “global configuration”. right now i have “site” “system” and “server”. I did this before, but I forgot what I did. I want to change the options for my articles so my metadata information for my articles reads:
    “html title”
    “meta tag description”
    “meta tag keywords”
    “robots metatag”
    Right now it reads:
    “descriptions”
    “keywords”
    “robots”
    “author”
    I tried downloading the SEF Patch but it says I am missing an xml setup file. Can someone help me please?
    histeriks Friend
    #335596
    wchua;168620Hi, I’m trying to insert “SEO” in one of the top tabs of the “global configuration”. right now i have “site” “system” and “server”. I did this before, but I forgot what I did. I want to change the options for my articles so my metadata information for my articles reads:
    “html title”
    “meta tag keywords”
    “robots metatag”
    Right now it reads:
    “descriptions”
    “keywords”
    “robots”
    “author”
    Hi wchua,
    If you are referring to this component (and i believe you are), you are not supposed to use the Joomla installer to install it, but rather use simple overwrite to replace Joomla’s files with this hacked files.
    In order to do that, extract the files in the Patch package and simply upload them, overwriting the files in your Joomla root (keep the structure of the archive intact co that each file get’s on the right place).
    Good luck 🙂
    wchua Friend
    #335663
    I really thankn you for your help. This means SO MUCH to me. It seems to be working just fine. I could not for the life of me find out how to install it. You are AMAZing.
    histeriks Friend
    #335673
    wchua;168725I really thankn you for your help. This means SO MUCH to me. It seems to be working just fine. I could not for the life of me find out how to install it. You are AMAZing.
    heheh, trust me, it happens to me all the time, trying to find some complex, obscure reason why things don’t work, and not even considering the simplest possible solution.
    Cheers 🙂
This topic contains 4 replies, has 2 voices, and was last updated by  histeriks 14 years, 8 months ago.
