  • ydrohoos1980 Friend
    #951224
    After joomla 3.6 upgrade when i open frontend media manager for intro image and full article image i cant close it. The media manager is open on a modal window, but you can’t close it.
    Is there any quick help for this problem?
    Pankaj Sharma Moderator
    #951272
    since the template is not officially ready for it , i suggest you to wait for updates and do not updated your live site and wait for official updates .
    Always take backup of site before update Joomla
    ketihar Friend
    #952873
    I can confirm that problem and i wait for fix.
    Charis Friend
    #953007
    Yes. I also have this problem. I can’t close the media manager modal on the frontend. The only solution that i found is to use protostar template on this specific page for article creation.
    ydrohoos1980 Friend
    #954490
    After updating to the latest T3 plugin and latest Purity iii template the problem is NOT solved!
    T3 plugin ver. 2.6.0
    Purity III ver. 1.1.7
    The problem is still there
    #954525
    Kindly provide a temp super user detail via private reply .
    ydrohoos1980 Friend
    #954578
    Thank you. I sent you private codes
    ydrohoos1980 Friend
    #954597
    #954618
    This seems to be Bug in the template , I created a bug report and sent this to development team for further investigation and fix , It will be fixed in the next update of template .
    You can track it Here
    ydrohoos1980 Friend
    #957269
    After update to joomla 3.6.2 problem fixed. This was a joomla 3.6.0 and 3.6.1 problem? This is weird
    #957386
    Great if this solve , I will also send this to developer for the same bug .
This topic contains 10 replies, has 4 voices, and was last updated by  Pankaj Sharma 8 years, 3 months ago.
