  • Roberto Sala Friend
    #179187
    Hi there,
    I’ve installed the quickstart package but when I try to visualize the site it goes to folder …/en instead of index.php.
    What is wrong?
    This is the site: faidatehobby.it
    Stork11 Friend
    #461685
    Hello wolfcub71,
    Did you install JA Wall quickstart package? I see that you marked “Solved” for this thread.
    Regards.
    arucardx Friend
    #461722
    My guess is his htaccess weren’t working properly and displayed the folder instead? Or the installation folder weren’t deleted.
    Seems his site is loading properly now.
    Roberto Sala Friend
    #461889
    Thanks for your answers. It was a problem with sample data. I reinstalled everything and it works but I have other problems now.
    Stork11 Friend
    #461993
    <em>@wolfcub71 331344 wrote:</em><blockquote>Thanks for your answers. It was a problem with sample data. I reinstalled everything and it works but I have other problems now.</blockquote>
    Hello wolfcub71,
    What is your problems now?
    Regards.
This topic contains 5 replies, has 3 voices, and was last updated by  Stork11 12 years, 5 months ago.
