Viewing 15 posts - 1 through 15 (of 16 total)
  • Saguaros Moderator
    #1068785
    Hi Valentio,
    May I know in which page where I can see the issue?
    Valentino Friend
    #1068823
    Could you share the correct URL to access backend and FTP account?
    Valentino Friend
    #1069059
    Valentino Friend
    #1069590
    Ok, sorry, i put your ip in the WAF whitelist
    Thank you!
    It’s weird, is this correct URL to access backend of your site? http://www.comeser.biz/administrator/index.php as it keeps redirecting to the homepage.
    And also share the FTP account.
    Valentino Friend
    #1070913
    Valentino Friend
    #1071276
    Valentino Friend
    #1072091
    Please try it now, I did some tests and it should work.
    Could you add exception for this IP: 113.190.254.239 ? as I still can’t access backend of your site.
    Valentino Friend
    #1072723
    I updated the file: /plugins/system/t3/base-bs3/html/mod_menu/default.php
    by adding 2 classes nav-pills nav-stacked
    into the line 21: < ul class="nav nav-pills nav-stacked menu<?php echo $class_sfx; ?>"<?php echo $id; ?>>
    You can check now.
This topic contains 16 replies, has 2 voices, and was last updated by  Valentino 7 years, 1 month ago.
The topic ‘Problem After Updating T3 2.7.0’ is closed to new replies.
