  • quyetdv Friend
    #818393
    Hi there. It seems there’s a problem with Ajax Filtering. It’s not working in my template. It was working fine, You can try it here: https://demo.vied.vn/index.php/vi/giao-duc-quoc-te/doi-tac.html
    Thanks in advance!
    Pankaj Sharma Moderator
    #819456
    @quyetdv
    Did u updated the Joomla or K2 recently on site ? or any customization u did on site ? It will help me to check this issue on your site .
    • post your site admin details via Private reply.
    quyetdv Friend
    #819584
    Mo0nlight Moderator
    #826348
    Hi Quyetdv.
    I just fixed the problem on your site. Below are details :
    Administrator -> k2 configuration -> Set jQuery library handling ->Load v1.11.x latest (remote copy).
    Backend jQuery & jQuery UI handling -> load local copy.
    Then edit the file : plugins/k2/jak2filter.php
    Add the code at the line : 28
    JHtml::script(Juri::base() . 'media/system/js/mootools-core.js');
    JHtml::script(Juri::base() . 'media/system/js/core.js');
    JHtml::script(Juri::base() . 'media/system/js/mootools-more.js');
    That’s it!
    Kindly take a look.
    quyetdv Friend
    #830242
    Thank you very much,
    My site has worked well.
This topic contains 4 replies, has 3 voices, and was last updated by  quyetdv 9 years ago.
