  • bullitt Friend
    #189263
    Hello
    sorry for my bad english i m french
    I have install only template (no quickstart)
    i have install joomla 2.5.13 + template Ja-mitius + jat3 + k2 2.6.7
    When i create a article and i create the link in the menu nothing appear on the page ….
    I think i forget a parameters but i dont know where can you help me??? if you need access to the site i can give you
    Cheers
    Bullitt
    <blockquote>I think i forget a parameters but i dont know where can you help me??? if you need access to the site i can give you</blockquote>
    Send me it via PM i will try to check directly on your website backend
    I changed some settings from your template manager
    1) Your template was using the Home layout ( No space for content block ) i switched it to Default layout
    2) Your Home menu item type was set as Featured Articles but your Joomla article was not set as featured ( Now it works )
    3) To have K2 articles showed on home page you need to switch your home menu type to K2 categories or another K2 type as Blog etc etc
    Please check your page now
    bullitt Friend
    #500264
    exact it’s working thanks very muche
    I read your notice thanks now I understand my mistake
    thanks very much
This topic contains 4 replies, has 2 voices, and was last updated by  bullitt 11 years, 5 months ago.
