  • chanthorn Friend
    #149997
    I have problem with field ID at resume detail form. ID should number but it shows name of user.
    i have added more field but this problem happened before i added some field more.
    There’s photo in attach file that can show the problem clearly.
    Thanks.
    1. Problem
    Anonymous Moderator
    #338683
    Hi there,
    It seems you have adapted some customization to this field. Please follow below steps to solve the problem:
    Go to JB back end>> Design and Customization => Form Customizations => Resumes Tables => Edit ID record => Select no for “Reference database”
    Hit save and hope it works fine now.
    chanthorn Friend
    #338737
    Thanks in advance 🙂
This topic contains 3 replies, has 2 voices, and was last updated by  chanthorn 14 years, 9 months ago.
