  • artaddicted Friend
    #130501
    1. I had JA install the quick start JA Drimia template.
    2. There is a missing image that produces a “red X” (IE6) and the image alt “Link” (FF) in the web links area: Now Fixed.
    3. The problem does not exist at the FAQ category listed articles: Now Fixed.
    4. Both appear to use the same: class=”sectiontableentry1″ and class=”sectiontableentry2″
    Note: I have verified that dot.gif is located in the proper folder.
    Could someone please help me fix this problem. Thank you in advance.
    artaddicted Friend
    #258517
    I paid JA to install the same version as on their server. This missing image was not even in the installed files. I put in the image, but it soes not appear that the code is calling it. It only calls the template image file. Unfortunately, I am not skilled enough to find and fix this problem. I have spent several hours trying to find it.
    Additionally, the news flash headline font is white on the JAA demo site, not the standard h1 that I was delivered with the install.
    Does JA do fixes for their version and not update the base template files. The JA promise of a 24 hour install was not completed until over 96 hours and it is not the same version as installed on their server.
    Any help fixing these issues would be greatly appreciated. Thank you.
    #259137
    Hi artaddicted
    I tested your problem with default Joomla, and that is bug of joomla, you can change to default template of joomla, and see that problem still there. I thinks that is bug of weblinks component
    artaddicted Friend
    #259147
    <em>@nguoiabcd 65753 wrote:</em><blockquote>Hi artaddicted
    I tested your problem with default Joomla, and that is bug of joomla, you can change to default template of joomla, and see that problem still there. I thinks that is bug of weblinks component</blockquote>
    nguoiabcd, thanks for you input, but I think you may be mistaken.
    Take a look at the weblink component in the JA demo, not a problem there, go to the weblinks: http://www.joomlart.com/templates_demo.php?template=ja_drimia
    Take a look at the newsflash on the JA Demo site. The heading and article are white: http://www.joomlart.com/templates_demo.php?template=ja_drimia
    Since both of the problems are clearly demonstrated correctly on the JA demo site. This leads me to the conclusion that there is a bug in the template code that was installed on my site, but corrected on the JA demo site. The only other possibility is that I have an incorrect setting somewhere. However, it was not my responsibility, I PAID JA to install the demo site as it was installed on their server. This is not what I received. I had to setup sever other features that are on the demo and were not installed.
    I apologize for being a burden on the forum with a problem that is clearly the responsibility, but, I have been unsuccessful in getting any other help.
    If anyone could provide a solution, I would greatly appreciate you help.
    artaddicted Friend
    #260843
    You are correct … this is a problem with Joomla, I was finally able to find it on my own. For those of you that may have the same problem, the easy fix is the last post found in this thread: http://forum.joomla.org/viewtopic.php?f=199&t=282291&p=1306036
    I stand by my comments … I paid JommlArt for the install, which was supposed to be a duplication of their demo site. This problem was fixed on their location and SHOULD HAVE BEEN FIXED BY THEM ON MY INSTALL.
    I still have no solution to the other problem that I cited in this post. Awaiting any input you can provide.
    artaddicted Friend
    #260848
    In administrator..
    1. Extensions => Module Manager
    2. Edit JA Newsflash
    3. In the “Templates” field add the following font color to the “Title” (See GREEN code below).
    <div style=”overflow:hidden;” ><div class=”nfimages”>##IMAGE##</div><div class=”nftitle”><font color=”#ffffff”>##TITLE##</font>]</div><div class=”nfcontent”>##CONTENT##</div></div>
    OK to make this as Fixed/Solved
This topic contains 6 replies, has 2 voices, and was last updated by  artaddicted 16 years, 5 months ago.
