August 21, 2013 at 1:59 pm #189920
I have a problem with the breadcrumbs module
It tells me the navigation path in any of the pages and I get the error
Notice: Trying to get property of non-object in C: xampp htdocs joomla_2.5 modules mod_breadcrumbs helper.php on line 35File helper.php line 35 is
$item->link = JRoute::_(‘index.php?Itemid=’.$app->getMenu()->getDefault()->id);
What should I do
- November 2014
- 3854 times in 3563 posts
August 22, 2013 at 11:28 am #503160I use PHP version 5.4.16
Although not if this problem causes the module stops working, because it does not show me the navigation path.August 22, 2013 at 12:31 pm #503166Any solution?
I saw the link that the issue is not resolved. I need to put the breadcrumbs!
Help!!Ninja Lead ModeratorNinja Lead
- November 2014
August 23, 2013 at 3:49 pm #503303If possible you can put your site to LIVE and pm me information access of your site. I shall help you to check the problem directly on your site.
August 26, 2013 at 7:12 am #503422I’m working in local server
- November 2014
August 27, 2013 at 7:41 am #503576<em>@asolellop 386456 wrote:</em><blockquote>I’m working in local server</blockquote>
I also try to look at JOOMLA forum and there seem to be some threads talking about the same problem like yours. It’s hard for me to help you if your site is still at local. Because I did check this JA University J!2.5 but I couldn’t duplicate the same error.
You can try to download quickstart package JA University J2.5 here and install it again
This topic contains 7 replies, has 2 voices, and was last updated by Ninja Lead 11 years, 2 months ago.
