  • newlalax Friend
    #151342
    Hi.. Sorry for my English..!!
    I Have installated with quickstart on my site http://www.reginasexy.it
    If I add a product to the cart without being logged in. I have this problem:
    1) Insert the product in the cart .. ok
    2) Click on the link of the truck “show cart” and redirects me to the summary page with the button ceckout .. ok
    3) when click “checkout” which should take me to the login page or data entry,
    the truck is empty and appears as “the basket is empty”
    If you do the procedure already logged the problem does not occur and everything runs smoothly.
    I set the permissions of files and folders to 755.
    If you want you can also carry out tests for registration ..
    Dear newlalax! i checked this issue on our demo and some dev site. everything are working well without the problem. can you pls give me the link adminsitrator account. but i do not make sure i can resolve it. so that pls keep contact virtue’s developers to get some best solutions on the issue. Thanks. PS: your ticket: HHS-254301
    newlalax Friend
    #344909
    Thank you for your availability ..
    but I’ll try to do a Fresh installation..
    It will also use other templates ..
    if the problem persists, maybe you do know
    Dear newlalax!
    I guess your site is having a problem with session variable, this need to debug and find solutions. You try to use other template ( can use the default joomla template) to test this, to find the problem from the template or from the component or session variable. You try to post this issue on the Virtue mart forum, you ‘ll get many best solutions to resolve yours
    Good luck
    newlalax Friend
    #345485
    whit on new installation, i dont’have problem with cart.
    thanks…
This topic contains 5 replies, has 2 voices, and was last updated by  newlalax 14 years, 6 months ago.
