  • hoogenraadmedia Friend
    #183218
    When I use the template (without K2, this would be overkill for this site), I have a problem with the contact page. The contact form and other information is not foldable.see: http://everlastproducts.nl/contact
    How to solve this at: or representation as in the demo
    or display as in standard Joomla (folding)
    1. contactform
    TomC Moderator
    #476701
    Just out of curiosity …. when you installed your template, did you do so via the quickstart+sample data installation process?
    #476712
    No, for several reasons. First come over all files with (such as language files which unfortunately is not inserted in Dutch) that you do not want, also sample data that is not documented, images like fruits which I nothing can.
    I install as clean as possible the plugins, modules and template. In addition, the Quick install version 2.5.7, current and installed 2.5.8.
    I saw that when installing an adaptation of the module contact page came up, but do not now from what it is adapted, I consider tomorrow the default files of this module reset to see if the contact page works properly.
    1. module-contact
    Stork11 Friend
    #477007
    Hello hoogenraadmedia,
    Can you PM me with your site admin account and your FTP one? So I can diagnose this problem.
    BTW, please include this forum thread URL in your PM, so I can follow it.
    Regards.
    smartmax Friend
    #479099
    Hi, I seem to have also a problem with the contact page… The ends of sentences aren’t visible? A little help would be nice 🙂
    http://www.sbrr.nl
    1. contact
    TomC Moderator
    #479100
    I just looked and things seem to be working fine – the text/content seems to be wrapping appropriately (i.e. no cut off).
    Viewed the site in both Chrome and Firefox browsers.
    smartmax Friend
    #479102
    Funny, I also work with ‘Firefox’ and this is what I see…
    Thank you for looking :-[
    #482394
    I send a login 🙂 Thanks for now
    Stork11 Friend
    #482623
    <em>@hoogenraadmedia 358683 wrote:</em><blockquote>I send a login 🙂 Thanks for now</blockquote>
    The account you PM was incorrect. Please re-check it.
    BTW, did you input an e-mail for contact? E-mail field must be filled so contact form can be shown.
    Regards.
This topic contains 9 replies, has 4 voices, and was last updated by  Stork11 11 years, 10 months ago.
