July 20, 2012 at 8:50 pm #179277
Hi, I’m a beginner joomla user, so please dont mock me if this is a stupid question, but, once I have installed the quickstart package for this theme, do I still have to install all the plugins, template, etc from the download section? or am I good to go? And second, I have installed this theme the first days of July, so I dont know whether I have the final version. I am trying to edit the module USER 1 so I can change those four icons for joomla, wordpress, drupal and magento for my own images and content, but when i edit in the backend nothing happens in front end. Do i need to re install and if so, do i install the quickstart package or Do i install plugins one by one (my first question)? Ill appreciate help
Sherlock FriendSherlock
- 2478 times in 2162 posts
July 21, 2012 at 8:05 am #461701Hi benmont86,
I am seeing that you are a newer to joomla, if that I think you would need to take a look at some joomla documentations for beginner to get a closer look in joomla to know what’s it and how to use it 🙂
Regarding your questions at this moment I Would like to reply as following<blockquote>Once I have installed the quickstart package for this theme, do I still have to install all the plugins, template, etc from the download section?</blockquote>
Once you installed the qs package you site would be looked exactly like the demo right after installing and you don’t need to install any thing more.
<blockquote>And second, I have installed this theme the first days of July, so I dont know whether I have the final version.</blockquote>
Yeah it probably is the latest version
<blockquote>I am trying to edit the module USER 1 so I can change those four icons for joomla, wordpress, drupal and magento for my own images and content, but when i edit in the backend nothing happens in front end. Do i need to re install and if so, do i install the quickstart package or Do i install plugins one by one (my first question)? Ill appreciate help </blockquote>
It’s maybe a caching issue, you would need to disable caching to see the change apply, once you want to re-install a module you just need to uninstall it then do install it again don’t need to re-install the quickstart.July 21, 2012 at 11:47 pm #461774<em>@Sherlock Holmes 331086 wrote:</em><blockquote>Hi benmont86,
It’s maybe a caching issue, you would need to disable caching to see the change apply, once you want to re-install a module you just need to uninstall it then do install it again don’t need to re-install the quickstart.</blockquote>
Thanks heaps for your great answers. About the module though, im still unsuccessful trying to edit it, I cleared the cache and I edited the USER 1 module again and nothing. and please, How do I actually change the icons (joomla, wordpress, drupal, magento) for other ones? Do i have to re install that module? Thanks a lot agianSherlock FriendSherlock
July 23, 2012 at 3:42 am #461826Hi benmont86,
Those 4 icons are added via a css rule, You open the file of templates/ja_zite/css/template.css look for this css
ul.cms .has-icon.icon1 {
background-image: url(“../images/joomla.png”);
Here you could see that the joomla icon is the image file of templates/ja_zite/images/joomla.png and others icons could be templates/ja_zite/images/magento.png, templates/ja_zite/images/drupal.png, templates/ja_zite/images/drupal.png, templates/ja_zite/images/wordpress.png
You can override those files with your own files.1 user says Thank You to Sherlock for this useful post
This topic contains 4 replies, has 2 voices, and was last updated by Sherlock 12 years, 2 months ago.
