November 15, 2017 at 1:40 am #1074372
Hello I have a problem when I connect in my administration I have a problem in the line 269. Help me he has you a solution for himself problem.
I am not able to login on the administration of my site.
Please keep me informed.
Pankaj Sharma Moderator
November 15, 2017 at 8:53 am #1074468Hi
It looks like you updated Joomla before updating the template and resulted in this error.
Kindly go to PHP Myadmin open the database and find _template_styles
Now ser the isis as default template as mentioned here.
Now update the JA Admin template to the latest version and then set this template to default.Hope it helps.
November 17, 2017 at 4:42 am #1074891Hello
I try to tell you what I have a problem with when I log in it still give me a wrong code when it’s a new person who log in my it has no error message like he never came to the site my me I still have an error code.
He has a solution
Thank you
November 17, 2017 at 4:46 am #1074893Hi
Did you set the isis as admin template?
Once you set it will not use the JA admin template and the error will not show.
I am not able to understand what you mean by the new user do not have this error.
Can u elaborate more on this?November 17, 2017 at 5:45 am #1074906When I say a new person who does not connect to him in the admin and it does not have error code my when his my team who still connect the message errror has the laundry 269. his bizzar mache to cert his walk and else not walk
thank you
November 17, 2017 at 6:51 am #1074911Hi
Sorry, but i am not able to understand your last reply.
Could u please apply the suggestion i suggested via phpmyadmin and change the template style to isis.
And after this step update the template to the latest version.
This will help you to fix this issue.AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 2 voices, and was last updated by
Pankaj Sharma 6 years, 9 months ago.
Problem fatal error line 269
