antoniocerasuolo Friend
antoniocerasuolo
- February 2011
- 7 times in 1 posts
phong nam Friendphong nam
- May 2015
- 974 times in 888 posts
September 26, 2013 at 7:14 am #507122Hi Antonio,
That is the customized layout of Featured Articles on our JA Beranis template. You can go administration >> Home menu item >> Then configure the settings in Layout Options and Article options of this menu item.
1 user says Thank You to phong nam for this useful post
antoniocerasuolo Friendantoniocerasuolo
- February 2011
September 26, 2013 at 8:51 pm #507228Hi leo,
i have a question:
i need to be able to show a database on the site therefore i need the possibility to view this database and also act on on it like maybee delete a row if i want to delete or maybee even modify or add a row.
but in general all database management will be done automatically.
do you have a free module that can do this that you can suggest??
ciao,
Antoniophong nam Friendphong nam
- May 2015
September 27, 2013 at 1:00 am #507230Hi Antonio,
You can try on one of below Database Management extensions at http://extensions.joomla.org/extensions/hosting-a-servers/database-management
- February 2011
September 27, 2013 at 1:11 pm #507312hi leo,
can you let me know where i need to put the favico.ico file ??
ciao,
- May 2015
September 27, 2013 at 1:15 pm #507315Hi Antonio,
It is really simple. You just need to replace the favicon.ico file in templatesja_beranis with your own file. Make sure it is also named favicon.ico .
- February 2011
September 27, 2013 at 2:08 pm #507325Hi Leo,
can you please let e know ho i can eliminate the small beranis logo from the site offline in the attachment?
ciao,
Antonio
- May 2015
September 27, 2013 at 2:21 pm #507328Hi Antonio,
You can open /templates/ja_hawkstore/css/offline.css file, find lines:
.wrap-offline-message h1 {
background: url(../images/logo.png) no-repeat left top;
color: #008DDE
display: block;
font-size: 0;
height: 30px;
line-height: normal;
margin: auto;
padding: 0;
text-indent: -999em;
text-shadow: none;
width: 170px;
The logo of offline page is a background image. You can change to your own image.
- February 2011
September 27, 2013 at 3:21 pm #507339Hi Leo,
those database management tools are not rerally what i was looking for..
i’m looking to view and manage the database on the front end ..
any ideas??
ciao,
- May 2015
September 30, 2013 at 8:13 am #507478Hi Antonio,
I came back lately. I think there is no extension like that in JED since the database is a really important part containing all website’s content, settings so that it will be better if it is controlled on your hosting account with required login info.
This topic contains 10 replies, has 2 voices, and was last updated by phong nam 11 years, 2 months ago.
