  • lapixelerie Friend
    #901470
    I try to make a command but tabs refuse to open… ! there is no javascript error. I really don’t understand why ! enter image description here
    thanks for you help !
    Could you check our demo site and let me know which page should I access to see the issue? http://ja-bookshop.demo.joomlart.com/index.php/en/
    lapixelerie Friend
    #901648
    Hello, here: http://ja-bookshop.demo.joomlart.com/index.php/en/checkout
    In my case, the tabs never open !
    Something wrong with Mijoshop on your site as when I tried to switch template of Mijoshop to default template (instead of JA Bookshop), the issue still happens
    Do you have any 3rd party extension installed on your site? try to disable them all first as I see the JS error in that check out page: http://prntscr.com/agqngt
    lapixelerie Friend
    #903290
    Could you pls update again the admin login info? as I can’t access with provided info. I will try to check it further for you.
This topic contains 5 replies, has 2 voices, and was last updated by  Saguaros 8 years, 9 months ago.
