January 13, 2009 at 6:26 pm #137059
Hi guy…my homepage has vanished again.
Using JaZeolite and not even within the party administration.
Error 500.
You can help me? Thank you very much …My site is http://www.ideapubblicita.eu .
I enclosed my logs fileTNX 4 ALL!!!
scotty Friendscotty
- March 2008
- 827 times in 595 posts
January 13, 2009 at 7:22 pm #286258AFAIK this is a server error. In other words it’s your actual server software and not a joomla issue. Maybe someone can clarify this?
SP Media FriendSP Media
- 70 times in 27 posts
January 13, 2009 at 8:02 pm #286266A server with that error just usually requires a reboot, but normally the server “hangs”, yours doesn’t.
scotty Friendscotty
- March 2008
January 13, 2009 at 8:06 pm #286267Maybe you have enabled SEF or edited your .htaccess file?
January 13, 2009 at 8:07 pm #286268<em>@spmedia 105859 wrote:</em><blockquote>A server with that error just usually requires a reboot, but normally the server “hangs”, yours doesn’t.</blockquote>
<em>@scotty 105860 wrote:</em><blockquote>Maybe you have enabled SEF or edited your .htaccess file?</blockquote>
no … I have not done anything of the sort.
I only change the permissions on the folder components / com_virtuemart in 744SP Media FriendSP Media
January 13, 2009 at 8:23 pm #286270Revert them back to 755 or 777.
January 13, 2009 at 8:25 pm #286271I did ….but nothing.
how do I reinstall everything without losing data and images already?SP Media FriendSP Media
January 13, 2009 at 8:31 pm #286273Can you get into the admin panel?
January 13, 2009 at 8:33 pm #286274no … I have tried all
January 13, 2009 at 8:45 pm #286276Ok, back up your database, via phpmyadmin, or whatever your host supplies.
Blank your configuration.php, and reinstall. Don’t reupload anything, or delete it just yet. Reinstall, and restore your database.
That should solve it.
Here’s some links to help; this is for wordpress, but the same applies to Joomla. It’s a video file, so it should make it easier.
http://www.francescolanza.com/2007/10/22/backup-restore-wp-db/
January 13, 2009 at 8:48 pm #286277yes, I know how it works.
do you know soon.SP Media FriendSP Media
January 13, 2009 at 9:00 pm #286279Do I know soon?
January 13, 2009 at 9:02 pm #286281sorry……..ahahahaha….my bad english.
I tell you: when I see the site send a message.
thanks now.January 13, 2009 at 9:15 pm #286283I can not restore the database because of an error on the line in 1788 sql file.
This topic contains 15 replies, has 3 voices, and was last updated by SP Media 15 years, 9 months ago.
