April 3, 2011 at 2:56 pm #162322
Dear Forum Members,
In the context of the 2nd menu (ja-cssmenu) a problem/question has arised:
When you look on our test-site at http://new.oeschger-brandschutz.ch , you see that the 2nd menu is set off vertically by a small gap from the horizontal main menu.
This is wanted.
The solution we have chosen is not quite the best. We have achieved this effect by adding a border with a white background onto the 2nd level ja-cssmenu li ul as you can see from the css code below:
#ja-cssmenu li a {
vertical-align: middle;
display: block;
text-decoration: none;
font-size: 100%;
color: #666666;
padding: 0px 25px 0px 25px; /* Rand gesamte Liste von Links und Rechts 25px und Schrift von oben 2px */
text-transform: regular;
line-height: 25px;
height: 25px;
background: ffffff;
border-bottom: 10px solid #ffffff !important; /* <– padding 2nd level menu from top */
}This method is not really targeting for example if you look at specific browsers. They draw a thin blue line around the 10px gap below the active (highlighted) item on level 1.
Question here:
Can somebody provide us with a targeting (correct) solution on how to span the 2nd menu from top AND draw a border line (1px) around the 2nd menu pulldown element.
Our website address: http://new.oeschger-brandschutz.ch
As already mentioned, the actually used method is more a helpless ‘workaround’ than a solution but it shall illustrate the wanted optical end result.
Any targeting advice is very welcome.
Best regards,
Netshare
chavan Friendchavan
- October 2014
- 1440 times in 1290 posts
April 3, 2011 at 5:48 pm #384668<em>@mmservices 231989 wrote:</em><blockquote>Dear Forum Members,
This is wanted.
#ja-cssmenu li a {
display: block;
font-size: 100%;
color: #666666;
line-height: 25px;
height: 25px;
background: ffffff;
Question here:
Best regards,
Netshare</blockquote>
Open this File: http://new.oeschger-brandschutz.ch/templates/ja_nickel/ja_menus/ja_cssmenu/ja.cssmenu.css
Replace the Css code
#ja-cssmenu li a {
border-bottom: 10px solid #FFFFFF !important;
color: #666666;
display: block;
font-size: 100%;
height: 25px;
line-height: 25px;
padding: 0 25px;
With
#ja-cssmenu li a {
color: #666666;
display: block;
font-size: 100%;
height: 25px;
line-height: 25px;
padding: 0 25px;
Hope this would be helpful
April 3, 2011 at 9:42 pm #384678Dear Chavan,
thank you for your message.
But i guess that you misunderstood us.
It is WANTED that there is a gap.
The construction with the help of
shall just be a temporary construction as it is not really optimal.
We ask for a BETTER solution on how to build this gap.
Any targeting advice would be helpful.
Best regards,
Netshare
<em>@Chavan 232003 wrote:</em><blockquote>Open this File: http://new.oeschger-brandschutz.ch/templates/ja_nickel/ja_menus/ja_cssmenu/ja.cssmenu.css
#ja-cssmenu li a {
color: #666666;
display: block;
font-size: 100%;
height: 25px;
line-height: 25px;
padding: 0 25px;
With
#ja-cssmenu li a {
color: #666666;
display: block;
font-size: 100%;
height: 25px;
line-height: 25px;
padding: 0 25px;
Hope this would be helpful</blockquote>
chavan Friendchavan
- October 2014
April 4, 2011 at 7:26 am #384719<em>@mmservices 232017 wrote:</em><blockquote>Dear Chavan,
Best regards,
Please provide us a screenshot of how it should look like.
April 4, 2011 at 5:17 pm #384824Dear Chavan,
it shall like as you can see on our website: http:/new.oeschger-brandschutz.ch but not with this clumsy border-command.
This is not professional made and is just a workaround for the moment.
any targeting input is appreciated.
Best,
Netshare
chavan Friendchavan
- October 2014
April 4, 2011 at 8:13 pm #384831<em>@mmservices 232218 wrote:</em><blockquote>Dear Chavan,
Best,
No this is the right way. Since the possibilty of removing the border-command is either padding or margin or even the height. If you set this either you can’t navigate to the sub menus nor the text of the Menu will overflow for the grey background.
1 user says Thank You to chavan for this useful post
April 4, 2011 at 10:18 pm #384842Dear Chavan,
thank you for this explanation. We will reflect on this and eventually change back the gap.
Another important question regarding the menu structure, if you allow:
we have a weird problem which cannot be answered by the forum public so far.
Eventually you can help us out of trouble?
If yes, we would thank you a lot in advance.
Below you will find a short problem description:
As you already know we are building up a JA Nickel website.
in our main menu (left side) we have 3 menu levels.
functionality is ok, menues are working technically well.
regarding the css design we notice a problem with the active/hover/passive state of the level 3 menu.
when the level 2 element (Sprinkler-Löschsysteme) gets an active state, all elements of level 3 (childs of ‘Sprinkler-Löschsysteme’ got an active state (underline) as you can see on the attached image.
this is wrong and unwanted.
our website: http://new.oeschger-brandschutz.ch
any targeting help is appreciated much.
with our best regards,
netshare
here are the code fragments of the left side ul.menu structure:
/* Default Joomla! Menu */
ul.menu {
font-size: 90%;
vertical-align: top;
list-style: none;
margin: 0px 0px 0px 0px;
padding: 0px 0px 0px 0px;
}ul.menu li {
margin: 0px 0px 20px 0px; /* Abstaende der Level-0 Bloecke im Splitmenu */}
ul.menu li a {
display: block;
outline: none;
margin: 0px 0px 0px 0px;padding: 0px 5px 0px 25px; /* Abstand Pfeile und Block im Splitmenu */
color: #666666;
border-top: 0px solid #E5E5E5;
background: #ffffff url(../images/strich_passiv.png) no-repeat 0px center;
}ul.menu li a:hover,
ul.menu li.active a,
ul.menu li a:focus {color: #666666;
margin: 0px;
background: #ffffff url(../images/strich_aktiv.png) no-repeat 0px center;
text-decoration: underline;
}ul.menu li ul {
list-style: none;
margin: 0px;
padding: 0px;
}ul.menu li li {
border: none;
margin: 0px 0px 0px 0px;}
ul.menu li li a {
background: #FFFFFF no-repeat 0px center !important;
border: none;
font-weight: normal !important;
text-decoration: none !important;
padding: 2px 0px 0px 30px!important;
width: 75%; /*need for ie6*/}
ul.menu li li a:hover,
ul.menu li li a:active,
ul.menu li li a:focus {
text-decoration: underline !important;
background: #FFFFFFF no-repeat 0px center !important;
color: #666666;
}ul.menu li li.active a {
color: #666666;
}ul.menu li li ul {
list-style: none;
margin: 0px;
padding: 0px;
text-decoration: none !important;}
ul.menu li li li {
border: none;
border: none;
text-decoration: none !important; /* <— this instruction has no effect, overridden by level 2, ul.menu li li.active a */}
ul.menu li li li a {
border: none;
padding: 2px 0px 0px 45px!important;
ul.menu li li li a:hover,
ul.menu li li li a:active,
ul.menu li li li a:focus {
text-decoration: underline !important; /* <— this instruction has no effect, overridden by level 2, ul.menu li li.active a */
color: #666666;
}ul.menu li li li.active a {
color: #11175E;
chavan Friendchavan
- October 2014
April 5, 2011 at 9:42 am #384934Please provide your admin details in PM. Since there are every where ” !important” in your css and it is quite confusing.
chavan Friendchavan
- October 2014
April 5, 2011 at 5:31 pm #385005Here is the CSS code to be replaced for the menu.
Delete the existing whole css for menu and replace this
ul.menu {
font-size: 90%;
list-style: none;
ul.menu li {
ul.menu li a {
display: block;
outline: none;
color: #666666;
ul.menu li a:hover,
color: #666666;
margin: 0px;
ul.menu li ul {
list-style: none;
margin: 0px;
padding: 0px;
ul.menu li li {
border: none;
ul.menu li li a {
border: none;
# width: 75%; /*need for ie6*/
color: #666666;
color: #666666;
ul.menu li li ul {
list-style: none;
margin: 0px;
padding: 0px;
ul.menu li li li {
border: none;
border: none;
font-weight: normal !important; /* <--- this instruction has no effect, overridden by level 2, ul.menu li li.active a */
border: none;
color: #666666;
ul.menu li li li.active a {background: #FFFFFFF no-repeat 0px center !important;
color: #666666;
ul.menu li.active a{
text-decoration:underline !important;
ul.menu li.active li.active a{
ul.menu li.active li.active li.active a{
ul.menu li.active li a{
text-decoration:none !important;
ul.menu li.active li.active li a{
ul.menu li a{
text-decoration:none;
April 5, 2011 at 6:01 pm #385010Dear Chavan,
yes, thanks!
This is exactly the correct solution, indeed.
Well done.
This is a 200% satisfaction guarantee.
With my best wishes from Switzerland,
Herbert
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by mmservices 13 years, 5 months ago.
Problem Gap between 1st Level Menu and 2nd Level Menu
