  • jbsarma Friend
    #886973
    Hi, I get something like http://assam.charitytrust.org.uk/installation/installation/…/index.php and a get a error page saying ‘Make sure you’ve got the right URL: http://assam.charitytrust.org.uk‘ with Ja_Charity as well as JA_purity as well. Please help.
    Hi there
    You will need to extract quickstart files into your public_html root folder then launch your website url from your browser http://assam.charitytrust.org.uk
    jbsarma Friend
    #887013
    Thanks – slight confusion. I have extracted to the subfolder within the public_html to which the domain mapped to. If I extract in the public_html itself I am confused how it will work. This is CPanel server.
    If you extracted into subfolder then the url will be http://www.yourdomainname.xxx/subfoldername/ it is weird that it doesn’t works it is more simple than it appears.
This topic contains 3 replies, has 2 voices, and was last updated by  pavit 8 years, 10 months ago.
