  • olivierdrouot Friend
    #178484
    hello, how do I make my sit appears under IE8, IE9?
    I can not change the language to display the template JA WALL, when I go to the HOME menu I can not change the language
    bonjour, comment faire pour que mon sit s’affiche sous IE8, IE9 ?
    je n’arrive pas non plus à changer la langue pour l’affichage du template JA WALL, quand je vais dans le menu HOME je ne peux pas changer le language
    Wall Crasher Developer
    #458815
    Hi olivierdrouot,
    I have checked your site and see that it runs well on my IE8, IE9.
    Can you please check again?
    For the language.
    JA Wall is support English be default.
    You have to translate those files by yourself:
    1. Copy /projection-immo/language/en-GB/en-GB.tpl_ja_wall.ini to /projection-immo/language/fr-FR and rename the it to fr-FR.tpl_ja_wall.ini
    2. Translate that file.
    3. Translate /projection-immo/templates/ja_wall/index.php
    4. Translate /projection-immo/templates/ja_wall/jswall.js
    And on menu ‘Evenements Mulhouse’ it does not show any content because there was no article inside category ‘Evenements Mulhouse’.
    Hope that helps.
This topic contains 2 replies, has 2 voices, and was last updated by  Wall Crasher 12 years, 6 months ago.
