  • librandi Friend
    #200602
    hi,
    the “read more” in the module “scegli la regione” in the home, does not work, while the same system in the region Calabria menu works perfectly. Why?
    thanks
    Hi @librandi,
    These articles under ‘scegli la regione’ may be not assigned to any menu item so when you click to read more, it still stay in the same page. You can try to assign articles (or category these articles belong to) to a menu item, it would work then.
    librandi Friend
    #546788
    hi Saguaro, thank you
    I try to explain better:
    1), the main menu (menu principale) does not appear in the home page, however appears the menu calabria
    2) the site is under construction, in the articles under “scegli la regione” the Calabria region is connected to the menu item calabria.
    can you try please?
    librandi Friend
    #546857
    Thanks I solved
    Glad to hear you sorted it out! Could you share your findings here? it would be helpful if others face the same issue.
    Thank you!
This topic contains 5 replies, has 2 voices, and was last updated by  Saguaros 10 years, 4 months ago.
